Can I transfer or move the product to another computer?
Find answers to the most frequently asked questions
Postby RS_Admin » Tue Nov 09, 2010 10:22 pm
Are you looking to transfer a ReviverSoft product, from your old computer to a new one?
Well, here is what you need to do:
Step 1: Uninstall the ReviverSoft product from your old computer.
( Start > Control Panel > Add or Remove Programs > Select the ReviverSoft product > Click on Remove/Uninstall )
Step 2: Download the ReviverSoft product onto your new computer, from our download center. Once the download is complete, proceed to install the product on your computer.
Step 3: Contact us with your request for a transfer, by specifying your activation key/license code.
Step 4: Use your activation key/license code to activate the ReviverSoft product on your new computer.
As simple as that! ;)
Good luck and enjoy your new computer. :)
Return to Frequently Asked Questions [FAQs!]
