How to create a God Mode tile in Start Menu Reviver
Discussions on Start Menu Reviver
Postby Reggie » Wed Aug 13, 2014 1:59 pm
What is the GodMode in Windows 7 and 8?
The GodMode is a hidden feature in Windows that allows users quick and easy access to all of the operating system's control panel options and settings from within a single folder.
How to create a GodMode shortcut tile in Start Menu Reviver
Step 1: Create the GodMode shortcut
Right-click an empty area on your desktop, select New and click Folder.
Next, rename this new folder to GodMode.{ED7BA470-8E54-465E-825C-99712043E01C}
You'll notice that the folder icon changes and is now called GodMode
Step 2: Adding the GodMode shortcut in Start Menu Reviver
Launch the start menu, drag the GodMode shortcut from the desktop and drop it onto an empty tile and you are set. You can now click the GodMode tile to access the GodMode folder when you need to. You also have the option to right-click (and edit) the Tile and assign a different image to it.
Hope you enjoyed this tip!
Return to Start Menu Reviver
