How do I prevent Privacy Reviver from running at every startup?
Here’s what you need to do to prevent Privacy Reviver from running at every start up:
  • Launch Privacy Reviver.
  • Click on Settings and select the General tab.
  • Ensure that the Run at system startup option is turned OFF.
  • Click on the Apply button to save the settings.
This will disable the program from running every time Windows starts.
You can always manually launch the program by double-click the desktop icon or accessing it from the programs menu.
Did this answer help?
